Fuel Pumps!!
Location: The dirty taint of the country. ...Los Angeles
Fuel Pumps!!
K,.....2 part question!!
1) how do I swap the pumps out?! ...(think'n about swap'n it out)
2) How can I diagnose that my pump is malfuntioning? (i'm not sure if it is or isn't)
If you think your pump is broke you can get a fuel pressure gauge and hook it up to your fuel rail. If you aren't getting good pressure their it's most likely your pump. Swapping it out isn't so easy to explain but it's not the tuffest job in the world.
This is the sticky at the top of this section:
https://ls1tech.com/forums/fueling-injection/599049-walbro-pump-install-information-here.html
I dropped my tank rather than cutting on my car.
