racetronix pump install problem
Im working on a buddys 01 camaro that he bought a short time ago. We got a 99+ racetronix kit for it when i pulled the tank down I found out and it already has a walbro 255 and the bottom of the plastic all cut away. does anyone know if this will effect the racetronix pump?
thanks for the help
thanks for the help
cutting out of the bottom of the bucket, i heard is for gas to get into faster cause they said that the old walbros wouldnt get the gas fast enough in the bucket which would cause failure. you might have to get a new bucket or stick with the same pump he already has in it, which fuel pump did you buy the direct fit?
the racetronix is a walbro pump but its a 270 and it fits in the stock location.. so i guess ill have to find a stock pump housing..
