ls1 tank/wiring
exactly what i needed to know...by any chance do you know what the lt1 tank has, i cant find any good pics, how many wires and what do they do? im trying to put and ls1 tank into an lt1 car, i know i need to reuse the lt1 level sender, im tryint to figure how im going to get it to work, and if i can use a ls1 racetronix kit
LS1TECH Sponsor
I'll verify the sending unit ohms (as I am currently building a few LT1 & LS1 double pumpers) & post the info later.
What are you doing for the fuel pressure regulator?
The LT1 has 3 wires as 1 sending unit wire is grounded internally.
The sending units will not fit in the opposite tanks.
I could probably build you a LT1/LS1 racetronix conversion pump/harness assembly if interested.
I have weekend hours, so you can call Sunday to discuss if interested.
