Factory injectors maxed out with no mods
I have a 99 Z28 that only has an airlid and a muffler for engine mods. I just got EFI Live, and my injectors are already hitting 80% duty cycle @ 5600 rpm. Is this normal? I was hoping I could do heads/cam and then upgrade if needed. But I guess not. What size injectors do the 99's have from the factory?
80%....correct me if I am wrong, but wouldnt it take quite a bit to max those out from there. I have 28 lb stock injectors in my car, with the mods in my sig, and i am only at 96% duty cycle at peak power. I am upgrading just to be safe, but this was in cold air, like 40* outside today, but I still want to be sure its safe, but I wouldnt think a decent sized cam and some good heads would completely max him out. I may be wrong though. But I would 20% would be alot left in there to play with....
Originally Posted by 98turbls1
You may see where you voltage is for your fuel pump...Could be falling off possibly...
Thanks for the replies everyone.
Kleeborp the Moderator™
You are dropping fuel pressure...it isn't being caused by voltage (at least not that I can tell)...it is just how our stock fuel systems work. My 28.8 lb stock injectors were at 90-95% duty cycle with just bolt-ons...looking at the fuel pressure at WOT told me why. In the upper RPMs, the pressure drops to 51-52 psi (instead of the 58 it is at idle).
What's your WOT a/f ratio? With full bolt-ons and my WOT table still stk (some where in the 11's) my injector duty cycle was in the 80% range. Just adjusting my WOT table to 13.1- 12.9 (n/a car) dropped my duty cycle down in the 60% range. Fuel pressure was always steady.
I have since upgraded the pump for future mods. H/C parts are arriving daily. I might have to upgrade the injectors after the install.
I don't know, I don't have my wideband installed yet and I'm still finding my way around the software and logging/tuning. I haven't changed anything that would affect the a/f ratio as tuned from the factory though.
