97 Corvette Fuel Regulator
I want a full return fuel system and have purchased a 97 Corvette fuel rail (GM P/N 12556705) and regulator (12554677). I was surprised to find a port on the regulator that I assume was connected to manifold vacuum. Since my PCM corrects injector flow rate for manifold pressure in software, I should leave the regulator port referenced to atmospheric pressure. Is this correct?
Thanks, Gary
Thanks, Gary
Thanks for the suggestions but I have a new question. I downloaded a supposedly stock 1997 Corvette PCM file and found that the IFR table is not flat – it is essentially identical to my 2002 LS1 IFR table. Where was the regulator port connected on the 97 Corvette?
