Wil my car run lean?
Old 02-28-2007, 05:39 PM
Timonator's Avatar
Default Wil my car run lean?
I'm putting heads, cam,headers,ls6 intake and an underdrive pulley on my car.Will the stock fuel system be ok or can I hurt my motor from fuel starvation?
Old 02-28-2007, 07:11 PM
2QUIK4U's Avatar
You should be okay. The stock fuel system is good to over 400rwhp, but some information on which heads and cam you are installing would help.
Old 02-28-2007, 08:15 PM
Timonator's Avatar
Livernois stage 2 heads,Speed inc. SI5 cam(231/237 589/595 112lsa).
Old 02-28-2007, 09:26 PM
Jake@EPP's Avatar
With stock fuel, those heads and cam MIGHT put it on the edge, a drop in pump from full throttle is about $150, Casper Hotwire $69.95 , 38lb/42lb/ or even 60lb ($419.99 you know the mod bug will bite you).
Old 02-28-2007, 09:47 PM
Timonator's Avatar
ok,but is there a chance of hurting my engine by using the stock fuel system for now?
Old 03-09-2007, 10:56 PM
24KTA's Avatar
No a stock fuel system is good for up to 500 HP, mine is all stock.
Old 03-09-2007, 10:58 PM
Timonator's Avatar
So, heads and a cam aren't 500 hp?
