Siemens 63lb/hr USCAR Hi-Z Injectors
Racetronix # LU107FM (Siemens FI114191)
This newly released injector from Siemens is the same as our L107 injector except that it has the new USCAR electrical connector. This USCAR connector (sometimes referred to as 'EV6 oval') is found on many late-model G.M. (LS2), Dodge (Hemi), Ford (Modular) and select import motors. This eliminates the need for costly in-line adapters or having to change the factory connectors.
http://www.racetronix.com/LU107FM.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by sultan(ZR-1)KSA
would thye fit 2002 corvette Z06 ls6
http://www.racetronix.com/L107FM.html
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by rmpage
Will these fit the LS2 without the need for O-rings and fuel rail spacers?
You would need to raise the fuel rails slightly.
__________________
>WEB SITE<
>WEB SITE<
Originally Posted by eb02z06
Jack will the LS2 fuel rials work on a LS1? If so do you just need the o-rings?
Thanks!
Thanks!
The mounting holes are in different locations and the crossover hits the top of the LS2 intake.
__________________
>WEB SITE<
>WEB SITE<
What is the diferance between the fuel injector you sell:
http://www.racetronix.biz/itemdesc.a...114191&eq=&Tp=
and this fuel injector:
http://www.bmotorsports.com/shop/pro...roducts_id/608
__________________
>WEB SITE<
>WEB SITE<
