Delphi/Lucas 42# Injectors
Anyone using these in a LS1 with no issues?
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Static Flow Rate: 48.83 lb/hr @ 58.0PSI (300kPa) or 370gm/min
I'm working on a LS1 that the owner took these out of his LT1 and put in his LS1 and it's doing some strange things that I can't quite nail down and I'm suspecting maybe it's an injector issue. Even setting a P0200 code (injector control circuit) occasionally. New O2s flatlining at idle and higher rpm, P0300. Lots of changes were made to the car all at once so it's hard to nail down what the exact problem is. I read another post here that someone thought they don't work will with the LS1 higher fuel pressure and are more suited to LT1s. Any thoughts?
Originally Posted by 2xLS1
Found the problem. #4 injector was unplugged. Might want to check your injector plugs if you ever get a P0200.
