Fuel Upgrades
Fuel Upgrades
I am pulling out the 10 bolt to swap in a Dana S60. What upgrades to the fuel system would you recommend at this time. I have a walbro 255 that drops about 4-5 PSI at wot. I am running at 465 RWHP. What do you think, what would you do????
What is your setup? What are your plans for the car? Do you have larger injectors or a hotwire kit? You should be getting more power out of a single pump than that if installed correctly. Maybe set it up with a return line and a front mounted regulator.
Nate
Nate
Nate,
I would like to call you to discuss. So you stock hot wire kits. Also, when I pull the assembly I can bring it to you to look over. I think you are about 10 min from me...
