Help-Installing SVO 30 Now Leaking
Well I just put a set of SVO 30's on the factory fuel rails. I got a leak on the last injector on drivers side. I lifted off the rail and resat the rails with the injectors. I cranked it and everything is fine than in started leaking again. Is there something I need to look out for? Also the retainer clips seem to not fit over the fuel rail and injector together? Appreciate any input, thanks in advance.
Also, I noticed if I remove the rail and set it in. If the front is pushed in the rear lifts a bit and if I push the rear in the front lifts. Is it possible I bent the fuel rail? Its only happening on the drivers side fuel rail.
Its all cool now. I didnt realize that the retain clip is sitting on the wrong groove. I quess thats what happens when you try to rush through it. I really didnt pay much attention to it yesterday either, it being Easter and all. Lesson learned for next time.
