New 90mm. throttle body coming out,maybe affordable?
MSD Throttle Bodies
In addition to MSD’s EFI Systems, MSD is also releasing throttle bodies for performance engines, starting with a 90mm cast aluminum throttle body. Yes, cast aluminum isn’t just for production engines, it’s for racing too. MSD’s throttle is designed with a parabolic bore shape. The parabolic bore allows for excellent drivability characteristics during part throttle. Typical billet straight bore throttles don’t have this cut, which irritates performance drivers when they have trouble modulating the power properly when navigating the track. MSD’s throttle body uses the same bearings, seals, and shaft design as production throttles. This allows for a very robust design that can stand the temperature swings seen by street applications without worrying about throttle sticking issues seen by other aftermarket throttle bodies. This throttle body is so good, it’s being used exclusively by GM Racing for their racing efforts in Daytona Prototype, SCCA Road Racing, and Dakar Hummer Off-road racing. MSD will be releasing more throttle bodies like this one in the future.
90mm Throttle Body ( PN 2240)
