Cleaning Injectors
Cleaning Injectors
have a bad misfire after storage.....what to you guys recommend to clean the injectors out once the fuel rails are off....tried the **** you put in the tank....but didnt clean it out...
you need to check them with a Multimeter for the correct impedence.. im sure someone can chime in here at let us know the correct voltage they should be at.. i have not done LS1 injectors yet so i do not know the correct impedence, and dont want to tell you something wrong...
ask in the Fuel section... its really easy to check this, and will narrow down your problem pretty fast...
could also be your plugs, or a plug wire..
