In need of larger injectors
10 Second Truck Club
The stock 19lb injectors are of no use anymore.
Has anyone swapped to the older (SVO) style injector. The wiring harness on the truck wont plug into the old style injectors.
Is there anyone who makes an adapter or is it a must to cut the stock harness and solder new injector plugs on?
We have a nice set of 37lb injectors we would like to use.
Re: In need of larger injectors
TIRBRNR are those injectors rated at 43.5 fuel pressure or 58, just curious? I have not heard of an adapter to do this type of install. Everyone I have heard of who swaps to SVO injectors has to splice the harness. I am not 100% sure if they make a harness or not though.
I here they are rated at 43.5 but i'm not sure. I'll keep checking for an adapter'if i have to do the harness...so be it. Thanks
