Which connector to run 39# cobra injectors?(Casper??)
Old 05-14-2007, 03:14 PM
sidewayz28's Avatar
Default Which connector to run 39# cobra injectors?(Casper??)
im trying to figure out which connectors i need to get my 39# Injectors off an 04' cobra to work with my motor..
do i need EV-1 to EV-6 connectors?
https://www.casperselectronics.com/M..._Code=newitems
or is it EV-6 to EV-1?
Old 05-14-2007, 05:15 PM
Silver02Z28's Avatar
The second one, EV6 to EV1.
You will need to shave a bit on the injector clip.
Or, instead of shaving, you can get these.
https://www.casperselectronics.com/M...Category_Code=
Also, let me know if you have any problems with your LTFTs when you switch these and scale your IFR. I've been there.
Old 05-14-2007, 09:36 PM
sidewayz28's Avatar
thanks for the link, i just orderd them! appreciate the help
Old 05-21-2007, 09:58 PM
sidewayz28's Avatar
ok well i got the connectors, and they say their LS7 to EV6 adapters.. one end connects fine to my new 39# Ford injectors, but the other side does not look like the ones that are connected to my stock injectors right now?? correct me if im wrong here..
edit: nevermind i think their right
