Ordered a Walbro 255 pump!
Hey guys, i just ordered a walbro 255 pump... my T/A needs it bad especially when i hit the nitrous....
can anyone recomend a good fuel filter? or do i just go with a AC Delco fuel filter??
anyone have any tips installing this pump? thanks.
is it the direct fit pump?if so also order the hotwire kit with it,youll need it for more voltage to the pump, you can either cut a hole on top of your deck lid just be careful their are pics on this just gotta search,or drop the tank which i did wasnt to bad,i just got done putting to back together which i install the tank by my self was a little tricky.
hey, yes the pump is for 93-97 camaro/firebirds.... i had no idea about the hot wire kit... do they make it for lt1's or just ls1's?? cuz where i ordered the pump they have a hot wire kit for 99-02 camaro/firebird.... i ordered from neweraperformanceparts.com
is this hot wire kit a must have??
i have nitrous in my car that is why im doing the fuel pump...
oh and i will be dropping the tank.... thanks.
We have seen good horsepower gains on the LT1 cars by just adding a Walbro fuel pump.
It most likely bumps up the fuel pressure which the LT1's seem to respong well to.
Here is the fuel pump Hotwire kit for the LT1's. Bob
http://www.exoticperformanceplus.com....html?item=742
