LT1 "trap door" location? where to cut?
I am interested in installing a walbro pump on my lt1 and had run across a write up for the ls1 on how to cut a trap door in the rear and drop the pump in... however they said it is a little different on the lt1 and in a different location. Does anyone have a write up or pics of the correct way of doing this for an 95 Lt1?
http://www.gonicd.com/intankinstall/...mpinstall.html
http://www.worldisround.com/articles/12533/index.html
http://www.taekwondoplus.org/z28/fuelpump.html
I went by these three websites. Make sure you have a good set of metal sheers and possibly even a dremel with good metal bits. It took me about an hour or two but I struggled on the quick connects.
Hope this helps!
Hope this helps!
