Speed Inc. Intank Pump and Regulator Questions
Does their direct fit LS1 intank pump keep the jet pump operational and include the intank wiring, sock, etc.?
Basically, is it similar to the Racetronix and Full Throttle Speed pumps, that don't require modification to the bucket and work the same as the stock pump?
My other question is where do I install the boost referenced regulator? before the rails or after the rails? I've seen it both ways.
