Fuel Return Line
Fuel Return Line
What year ls1's had fuel return lines im curiouse because im going to be installing a typhoon intake manifold and there is a seperate kit to buy wth a regulator. i think im in the clear because I have an 01. thanx for the help
The regulator in 99+ F-bodies is in the bucket. Any excess pressure/volume is returned back to the bucket via the "T" connector under the car. If you want to run the seperate regulator you will need to pull the regulator out of the bucket. You should be all set without the external regulator.
