LT1 -LS1 fuel system change over...
Alright, its finally time to tackle the fuel system in my car. Here is the deal. I'm puting a H/C/N20 6.0 liter into my 95 TA. I've thought about switching the tank and all the lines to make it a plug an play fuel system. Then you have to worry about the wiring and then the gauge accuracy.
I am leaning towards using the Vette filter/regulator. What I want to know is what lines m I going to need to go from the LT1 tank lines to adapt to the filter/regulator? Also, what do I do about fittings coming off the filter/regulator and going to the fuel rail of the LS6 intake?
Anyone who has done this, please chime in. I want to make this as painless as possible. Even if its directing me to someone or a sponser than would be able to help me.
Thanks in advance guys. This is tha last piece of the puzzle for this project.
10 Second Moderator
I'm doing the same thing only in a Camaro, I will swap in a 98 tank and use the short return style regulator thats in the tank. Seems easier/simple (plus I have the lines/line from a 98) I parted out last year. I'm thinking its just a wiring issue from there on out...
Originally Posted by Nasty N8
You can leave it all intact and add the reg up front to the rails stock lines and all. give me a call I will set you up with what you need.
Nate
Nate
