Cam only Ls1! Should I upgrade my injectors!!
Old 06-15-2007, 02:48 PM
nhra_crazy's Avatar
Default Cam only Ls1! Should I upgrade my injectors!!
I am doing a cam swap in the next few weeks with a Joe O cam. Specs
specs are 228/232 595 LIFT 110-LSA, also am adding a Ls6 intake,ported and polished throttle body and maf. My question is I have a set of 36lb injectors that I want to put in also. Will this be to much with stock heads?? It will be getting a tune. And anyone think I may need to upgrade the fuel pump?? The cam came out of a car with stock fuel system. Or should I just use my stock injectors and fuel pump??? Also will be upgrading the springs of course and pushrods.
Old 06-15-2007, 10:34 PM
nhra_crazy's Avatar
anyone???
Old 06-15-2007, 10:48 PM
BADBOYZ28's Avatar
I would put the 36lbs ones in. I'm running 42lbs ones with a cam only setup also. As far as the fuel pump if you can upgrade it why not better safe than sorry!!!
Old 06-16-2007, 12:57 AM
2QUIK4U's Avatar
The stock injectors and pump will be ok with that cam, but if you have 36# injectors just laying around it couldnt hurt to put them in. Just be sure to get a tune otherwise it wont run well.
Old 06-21-2007, 03:39 AM
SMOKKINU's Avatar
i would get 32lb injectors. if you plan on doing heads and nitrous...
36lbs seem a lil much to me...they might decrease fuel mileage alot. unless im wrong in the way these things work, which is always possible.
wish i knew you had injectors, i would have traded you the cam plus a lil cash for them lol.
Old 06-21-2007, 09:51 AM
Redlinez's Avatar
I've been thinking about the same thing. One member here who made crazy rwhp with cam only car was running 42lb injectors.
Old 06-21-2007, 01:26 PM
nhra_crazy's Avatar
Ya I mean there here why not just put them in now and tune them down. It shouldnt hurt my fuel mileage if they are tuned in right.
Old 06-21-2007, 02:04 PM
2QUIK4U's Avatar
I run 42lb. injectors in my H/C car. They are more than enough but long as they are tuned properly they dont hurt mileage at all and you have more fuel available if you get heads or a power adder later. For your application the 36 lb. injectors will work fine. You are getting a cam so a tune is necessary anyway so you may as well get the injectors installed so you dont have to get another tune later.
Quick Reply: Cam only Ls1! Should I upgrade my injectors!!
