Adding inline pump - LS1TECH
Adding inline pump
Thread Tools Search this Thread
Old 06-22-2007, 07:26 PM   #1
81LS1Camaro's Avatar
Default Adding inline pump
I know there is most likely a answer to my question on here but I cant find it. I have a 2000 SS that has a Bosch inline pump, but the pump has been bypassed with a piece of rubber line and I assume it is junk. Can I just replace it with a Walbro 255lph pump? Will there be problems with fuel pressure then? Is there something different about pumps sold as bap's? Any help would be great.
81LS1Camaro is offline   Reply With Quote
Old 06-23-2007, 01:12 PM   #2
Anyone? I also forgot to mention the reason for the extra pump is for the nitrous.
Old 06-23-2007, 02:44 PM   #3
LS1TECH Sponsor
Lonnies Performance's Avatar
Inline pumps generally can help increase fuel pressure, but may be limited in flow based on the pump in the tank.
You should upgrade the intank pump & then you can eliminate the external. This will be quieter & provide better flow than a stock intank & external combination.
I have Racetronix kits in stock for your car.
Lonnies Performance is offline   Reply With Quote
Old 06-23-2007, 02:54 PM   #4
I was wondering if I could just throw a walbro inline because they are only $98 and the car is already set up for it.
Old 07-28-2007, 01:05 PM   #5
Anyone?
Old 07-30-2007, 09:02 AM   #6
TECH Cry Baby BOSS APPROVED!
I had a Vortech inline pump and it was very annoying at start up. I would go with a bigger pump in the tank.
Urban Legend is offline   Reply With Quote
Old 07-30-2007, 01:51 PM   #7
Hemi Sponsor
Nasty N8's Avatar
As was said. And prob why the pump was bypassed. You need a bigger pump intank as you will get extra pressure from the external but not extra volume as you can not pull more fuel through the stocker in the tank.
Nate
Nasty N8 is offline   Reply With Quote
Old 07-30-2007, 02:29 PM   #8
I will go with a in tank pump for next year, kind of running low on funds this year. Got a few other things to take care of first, will just have to wait and spray next year.
Tags
extra, inline, ls1, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
