Stock Location Fuel Cell
Anyone Know Of A Fuel Cell That Can Be Mounted In The Stock Location And Hooked Up To The Stock Fillerneck..
My Shop Said They Could Not Find A Fuel Cell That Would Fit In The Stock Location And That Had A Fill Hole On The Side Of The Tank...
The Car Is A 2002 T\a
We make a race tank that fits in the factory location and uses the factory fill.
http://www.nastyperformance.com/FuelSystems.html
Nate
Nate
where the stock tank is if you get hit that the tank gets hit the guy behind you had to be hauling and you got more to worrie about other than the fuel tank. the stock tank dont have a blatter eather.
Side Impacts? Rolls? Punctures? How About If You Loose Your Rear At A High Speed And Have A Side Impact?
In Anycose Im Not Tring To Compare To A Stock Tank ... Im Looking For A Safer Alternative
The "well You'll Be Dead Anaway" Answer Dosent Make My Chances Of Living Any Better.. I Dont Think Anyone Will Argue A Fuel Cell Is Safer Than A Gas Tank In Any Accident..
In Anycase Thnaks For Your Help....
Nate
Nate
You guys need some better pictures on your site. Those tiny *** 157x117 pics are horrible.
Sorry about that I am working on something there. Here are some great pics for you.
And to the OP I have not seen one of our tanks puncture yet and they are quite a bit stronger than a stocker. Your stock location is up inbetween the frame rails only way I see a problem is if something comes from under the car and you could make a sheild for it from there. Our tanks have been used for all sorts of racing RR, Silver state challenge, drag....
Nate
https://ls1tech.com/forums/fueling-injection/671867-got-our-new-tank-nasty-awesome-setup-pics-inside.html
Nate
