what size injectors and what fuel pump for me???
Old 07-10-2007, 12:56 AM
99DWPTA's Avatar
Default what size injectors and what fuel pump for me???
i have 5000$ to spend-looking to do it wisely
buying AFR 205
fast 90/90-sending it to vengence to port it
CAM-unknown dont know which one yet
direct port nitrous system ZEX for FAST manifold
I have SLP long tubes gmmg catback
slp intake
msd coils-wires etc
What size injectors do i need-what brand please help
also will a Walbro 255lph high pressure be enough for my application. if not what pump do i get.
also do i need a new MAF sensor?-if so what kind brand etc
thanks guys
Old 07-10-2007, 05:23 AM
Former Vendor - No longer Vendor
ArchetypeZ28's Avatar
http://www.rceng.com/technical.htm
You can use that to figure what size injectors you will need
Old 07-10-2007, 10:41 AM
Nasty N8's Avatar
How much nitrous? May need Twin Walbro setup to support the nitrous.
Nate
Old 07-10-2007, 11:53 AM
99DWPTA's Avatar
i wont be doing more than a 150 shot
Old 07-10-2007, 02:54 PM
JoeMama's GTO's Avatar
To follow on to this discussion is there such thing as too much injector in terms of tuning/drivability? I am also looking to do a 150 shot and know I will need 42# to do it. However if I want to add more cam later I will need 60#'s and I don't want to buy/install injectors twice. I didn't mean to hijack and think this may help 99DWPTA as well.
Old 07-10-2007, 04:26 PM
2QUIK4U's Avatar
I would recomend 42lb. injectors and the Racetronics fuel pump. My stock injectors ran my H/C combo at 450rwhp with no problem. I just upgraded to the 42lb. injectors and Racetronic pump for the spray.
Old 07-10-2007, 04:29 PM
brad8266's Avatar
-Ford 42 injectors
-Walbro 255 lph pump
-Standalone fuel cell(low pressure) for the direct port kit
Thats how I would do it. That way you can run 93 in the tank and 110 in the cell. Extra safe. You got the $$ to do it, may as well do it good.
Old 07-10-2007, 04:31 PM
2QUIK4U's Avatar
You will need a tune with any upgraded injectors for it to run properly.There is no need to go to 60lb. injectors unless you are going with some sort of FI such as a supercharger or turbo.
Old 07-10-2007, 04:33 PM
brad8266's Avatar
Just in case some of you dont know already, if you run a wet kit there is no need for a larger injector, fueling is supplied directly off the fuel pump and through the nozzle. Only way you need injectors is if you run a dry kit.
Old 07-12-2007, 07:31 AM
I am thinking about a 150 RWHP Dry Shot and 80 RWHP worth of cam so that makes for about 265 crank HP on top of a 400 HP LS2 which equals 665 HP at the crank. Entering that along with a BSFC of 0.6 and a rail pressure of 50 psi into the fuel injector calculator gives about 57# injectors at 80% duty cycle. Considering the rail pressure will probably not be that high when the juice hits I am thinking 60's are going to be a necessity.
