Best price on 75 pound rcs?
Ok will just run the 60s .How much can you raise fuel pressure in the ls1? So how much can I make the 60s support before have to go to 96 or so low impedence. Can the 60s support 850rwhp at 80% or under with enough fuel pressure and is that pressure ok? I am going with twin fuel pump aps system with rails and adjustable reg and lines. Supposed to be ok for 1000rwhp.
You will have to run the mototrons at ~85 psi to make 850 RWHP with a turbo. That is a little high for the fuel pumps.
I'm going to go back on my recommendations and say get the 75 lb injectors instead.
To get around the static issue I run my fuel pressure at 42 psi with a 1:1 rising rate fuel pressure regulator (you need to have the 1:1 regulator).
Running the car in Open Loop - Speed Density will 95% of the injector's quirks right off the bat.
