APS C5 extreme fuel system-1000 RWHP fuel supply for 03/04 model C5
Hi Guys, Just thought you'd all like to see the new 1000 rwhp fuel supply system for the 03/04 model twin turbo C5/C5 ZO6 Corvette, enjoy!
Peter
http://www.airpowersystems.com/guide...-fss09/bom.htm
Peter
Originally Posted by Bluewire
How about some pricing information, any specials???
Thanks,
Peter
Coal Mining Director
Originally Posted by peter@aps
I wil have firm pricing on the 03/04 model C5 extreme fuel system within the next week or so..............I'll post up that info as soon as I can.
Thanks,
Peter
Thanks,
Peter
Walbro pumps?
Correct, twin 342 walbro fuel pump.
Peter
Peter
Originally Posted by onfire
I'd have your engineers spec a max pressure for 1000rwhp. If someone tries to boost reference Mototron 60's with a base pressure of say 70psi and push 20psi of boost....the 342's will drop off bigtime in flow at 90psi.....actually they drop pretty hard starting around 70psi.....don't ask me how I know
Peter
Typical 342 on a bench:
50psi 390lb/hr 8.5amps
70psi 335lb/hr 10.9amps
100psi 200lb/hr 15.4amps
Thanks,
Peter
Twin GSS 342 Walbro fuel pumps have sufficient fuel flow for around 1200 HP at 11.1 air fuel ratio as long as the fuel supply line/lines are large enough, APS utilizes twin - 6 teflon lined braided stainless steel fuel lines in our extreme fuel systems.
I estimate the 1200 HP flywheel would be around 1000 rwhp.
Peter
