Boost-A-Pump Question - LS1TECH
Thread Tools Search this Thread
Old 07-22-2007, 06:43 PM   #1
BBM98C5's Avatar
Default Boost-A-Pump Question
I have a question about my boost-a-pump. On Tuesday, my car had no fuel pressure as my fuel pump would not kick on. I got to the wiring and checked itgoing and coming from the boost-a-pump, checked all fuses, and checked the relay for the pump and there was no problem. After the boost-a-pump where it connects to the fuel pump wiring, I have my aftercooler pump wired, so I know the problem is before there, because the aftercooler wasnt working either. After I checked all of the wiring, I turned the key on and the pumps kicked on. Today, the same thing happened, except for I just tapped on the BAP and tried the key and the pumps kicked on again. My question is, can the BAP go bad and be causing there to be no power sent out of it? The car has had the BAP for 2 1/2 years and this has never happened before, and the BAP was used when I got it. Do you guys think it is time for a new BAP?
BBM98C5 is offline   Reply With Quote
Old 07-23-2007, 04:03 PM   #2
Hemi Sponsor
Nasty N8's Avatar
Never seen a bad one but it is possible as it is just a fancy relay. It is either that or a bad connection somewhere.
Nate
Nasty N8 is offline   Reply With Quote
Old 07-23-2007, 04:55 PM   #3
BBM98C5's Avatar
Yea, I was thinking a it could be a connection, but it has never happened before in almost 3 years, so I didnt think that was what it was.
Old 07-23-2007, 07:59 PM   #4
Hemi Sponsor
Nasty N8's Avatar
Could be corrosion over time. Just something not touching 100%.
Nate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
