injector size
Old 08-04-2007, 01:21 PM
one fast ss's Avatar
Default injector size
does anyone know how big of an injector the stock computor can handle? or is there any limit to to stock computor?
Old 08-04-2007, 02:08 PM
Default forgot to add
the injector size for an ls1 engine lol sorrryy
Old 08-04-2007, 03:06 PM
3.4camaro's Avatar
There is no limit, because the computer just uses pulse width to control it. It doesnt think "i need XX cc's of fuel"
Theres people on this site using 160lb injectors, I think you'll be ok.
Old 08-05-2007, 01:35 AM
bigtymn's Avatar
any high inpedance injector i think up to like 65lbs or something like that
Old 08-05-2007, 01:40 AM
Paint_It_Black's Avatar
To go to a low impedance injector, would you need to change the injector drivers like I had to do with the old ECM in my GN?
Old 08-05-2007, 11:31 PM
yeah thats what i thought 65 is the max i think on mine..but to change the drivers would i need a new computor?
Old 08-06-2007, 06:26 PM
3.4camaro's Avatar
probably not. You may be able to tune it.
Old 08-06-2007, 07:42 PM
joecar's Avatar
Not a new PCM, but external drivers.
Old 08-07-2007, 11:46 AM
408z28's Avatar
Your factory pcm will control any high impedance injector(if you reflash the pcm). With that said the biggest high impedance injector is 72 lbs/hr. You can run a low impedance injector, you will have to get a external driver (AEM,Big stuff 3, etc.)
