which pump for built 408 with 200 shot???
so i still here in Iraq been here 13 months now! snice i've been here i have all my parts to build my own 408. this will be a nitrous motor, i will be going with 60# injectors and just not sure which pump to go with?? any suggestions and pros-cons?? how many gph??
i was also thinking of just going with a dedicated fuel sys. to be on the same side! but also more pricie..
so what do you guys think thank again
I was running a similer setup and I went with a bosch 420l pump that speed inc sells. A stand alone isn't a bad idea though. You can put good gas in there and not have to worry about supply at all.
You could do Our Lonnies/Racetronix twin Walbro intank setup. Running one pump for your motor and the second kicking on for the nitrous. That way you will have plenty of fuel and a stock appearance. The stock regulator would be the week link so I would rec. our stage 3 street kit.
Nate
Nate
