Does any one know what size the injectors are that come on an L76 manifold and what pressure they are rated at? The forum search doesn't seem to be working. thanx
i thought i read they were 36lbs.. not sure at what pressure but im going to assume @ 55psi.. not sure though.. but you will need the injector conversion harness's to run those L76/L92/LS3 injectors on an LS1/LS6 engine harness..
