42#er delphi/lucas racetronix injector tabls
Old 08-18-2007, 10:45 AM
ZL1Killa's Avatar
Default 42#er delphi/lucas racetronix injector tabls
i was wondering if anyone knew/had the small puls width, def puls , min puls and what not values or tables that work fine for them.
whats happening to me is there is a slight hesitation around 1200-1400 that the car jumps for a second and it didn't happen before the injector install; im going to try and log it but i might only have a few things selected to log as it happens so fast. i can give it gas and it goes away
Old 08-20-2007, 11:18 PM
Frost's Avatar
you are a good bit north of minimum pulse by that RPM range (unless you are speaking of off/on throttle conditions), back to basics, put the car back in open loop, reset trims (yes they will still be remembered and applied, I say this because your open loop scanner config likely doesn't log the trims and it's common to forget) and get some logs. Personally, if I had already been over the VE and MAF, I'd apply the obeserved error against the MAF table. Easy, quick, and effective. Good luck.
