Need fuel line help, for supercharger install!
Old 08-23-2007, 11:31 PM
onefastbird95's Avatar
Default Need fuel line help, for supercharger install!
I am installing a supercharger on a 95 lt1 and I did the fuel line mod and welded shut the original hole they came threw... I have them comming up from under the wheel well, up over the power steering and along the fire wall... Couple problems... the original hardware that connects to the fuel rail is a 90 degree piece and point the fuel lines back or forward and kinks the line... secondly I had to cut the fittings off to shorten the lines. One line is supposed to go back into the 90 degree fitting that hooks to the fuel rail and the second fuel line is supposed to fit onto the vortech steel braided line that goes to the fmu. I can't get either fuel line to over the fittings... tried heating them, boiling water, everything! they just won't fit! what are my options at this point to get my fuel lines back together? as soon as I get this done I can finally start my car after months of installing a supercharger! any help is greatly appreciated! thanks
Old 08-25-2007, 06:26 PM
Can anyone help???
Old 08-27-2007, 11:59 AM
Nasty N8's Avatar
Not sure what you are describing a pick might help out.
Nate
