car will randomly not start (no fuel)
Old 11-27-2007, 11:21 PM
needaz28's Avatar
Default car will randomly not start (no fuel)
I just got my z about 2 weeks ago. for the first week not a single problem. then on monday while trying to leave for lunch at work the car wouldn't start. it was getting no fuel. I popped the hood and checked the fuses.all good,next I checked that all the elec. connectors that are fuel related were nice and tight. all good,after about 2 minutes of sitting it just fired right up. I thought it was because the fuel level was near E. (the check gauges light came on as I pulled into work) I went and got fuel, and the car was fine. next morning (today) car fired first try and I drove to work, sat till lunch and fired first try. after work I stopped at the bank was inside for maybe 5 minutes. I came out and it did it again, there is/was about 1/4 tank of fuel. after a few minutes started right up.
I was thinking that the line is losing pressure after it sits a long time, but after it did it again today after only sitting for maybe 5 minutes I'm kinda lost. I ordered a 255 and hot wire kit and plan to install it when it gets here as well as co over the whole fuel system.
does this sound like a dieing pump,air in my lines from being low on fuel,or some thing else that's not turning on the pump. when it's not acting up the car starts on the first crank it seems.
any insight would be great.
thanks
Old 11-28-2007, 08:36 PM
Banging some gears
greyghost4x4's Avatar
im having the same problem! anyone have any solutions?
Old 12-05-2007, 01:20 PM
hvyhttter's Avatar
check the usual fuse and relay, then check the signal to the fuel pump relay and see if the computer is sending a signal for starters
next it coulb be a bad pump be I wouldnt lean towards that since they are not usually intermintant
Quick Reply: car will randomly not start (no fuel)
