injectors not pulsing, have spark
Old 10-04-2008, 11:54 AM
wesmc's Avatar
Default injectors not pulsing, have spark
Just dropped an LS6 in a Porshe 944.
I have spark, no injector pulse. If I spray starting fluid it fires.
There is power to both sides of the injector, niether side ever goes to ground. Plugs are sparking, does this indicate the CPS is OK?
I have a standalone Delphi so there are no VATS issues. I checked all the simple stuff, power, grounds, batt charge.
Ideas?
Old 10-05-2008, 01:07 PM
cutlass73's Avatar
I have the same problem, LS1 in a 91 RX-7. Also only runs on ether.
Hooked a NOID light to an injector on each side.
Flashes twice and then stops during cranking.
Any insight on this?
Old 06-15-2010, 09:24 PM
vt951's Avatar
I'm having the same problem. Put an LS1 into a 944 turbo. I pulled the rail and injectors, and when I crank it, looks like they puff one shot of fuel each, and then nothing. Any ideas?
Old 06-15-2010, 10:49 PM
ls1whip's Avatar
do you have acsess to a automotive scope?
