Are these 3 or 4 ch axles?
don't see a wire going to an ABS sensor on each wheel so I would say 3 channel. If you need some actual axles for a 4 channel/Traction Control setup I have a pair from my old ten bolt: they have the gear/reluctor on them that the ABS sensor uses to calculate if there is wheel spin.
They look similar to this (but not as shiny and these are from my new MidWest 9" rear):
The car is a 4ch car....The rear came out of a drag car with no abs/tc etc - just the bare bones. I have the backing plates for a 4ch setup, i was just wondering if these axles were 4ch or 3ch..
Can 3ch axles be made to fit the backing plates? The rear is a Strange 12 bolt with 33 spline axles..
