which gears with nitrous?
Old 10-29-2008, 04:51 PM
blackls1ta00's Avatar
Default which gears with nitrous?
in the spring i will be using a moser 9 but just wondering which gear to use im looking at 600 to the wheels with nitrous,and going to use a 275 or 315 drag radial 17 rim,shud i use a 410,430,or a 456 with nitrous without using 5th gear?
Old 10-29-2008, 05:13 PM
DiabloFormula's Avatar
I was going using a 3.73 gear on 26" tires and seem to be running right thought the traps at 6-6200RPMS. I'll be getting my Fab. 9" here soon and thats coming with 4.11 gears but I will be running a 28" tall tire which will put me right around a realistic 3.90 gear, so I should be right on with the traps and RPM i hope, not quite the answer you were looking for, but maybe it'll give you a starting point.
Old 10-29-2008, 05:40 PM
SS1875's Avatar
Midwest Chassis Fab 9 running a 3.90 gear and will see Nitrous at the track, more than likely a 28 tall tire as well...I think this should be about perfect for going through in fourth gear without any issues of the Rev Limiter. (Mine will be set @6800)
Old 10-29-2008, 09:54 PM
blue99fbody's Avatar
im making around 550 with 4.10s in a 12 bolt and am hitting the revlimiter at 6700 at the line @125 but another guy around here somehow did 130 on 4.30s making little over 600whp he said hitting rev limiter in 4th both on 26 in tire ???
Old 10-30-2008, 12:41 AM
BriancWS6's Avatar
It all depends how high your willing to rev it. With 600whp, I would look into some better tires than a 17 inch DR.
Old 10-30-2008, 06:02 AM
cabel1's Avatar
I have 4.30's with a 27" tire. On motor I was around 6200 @116 on the spray I'm at 7050 @126.
Old 10-30-2008, 07:55 AM
rpmauto's Avatar
sorry to hijack, but i am wondering the same thing. I make 620 with juice, for now. I have not made a good n20 run this year, but with 4.10s i think i will be on the limiter 6800. I have 3.73s now. I know 4.10s would be perfect for motor only, but on spray i think i will have to get into 5th. How much would a 28" tire help? and will a 28 fit with no modifications?
Old 10-30-2008, 08:50 AM
A 28" tall tire will help you get out of the hole with out spinning as much as a 26" tall tire will, as for the 28" tire fitting, it really all depends on what 28" tire you're going with.....
For example, a 28x10.5x15 ET drag has a wider tread and section width then a 28x11.5x15 ET Street and the ET Street is really a 27.6" tire and has a treat width of 8.9" or something like that, where the ET Drag is really a 28.1" tire and has a tread width of 10.0" as well as a wider section width. So besides the usual bumpstop cutting mod, the ET Drag would need some pounding of the front inner fender well where as the ET Street would not, so when choosing a 28" tall tire make sure you look at the tread and section widths to help a little on the mods that might need done to get the tire to fit.
Old 10-31-2008, 01:36 PM
Midnight02's Avatar
With 4.10's on a 17" tire you should be tearing into the rev limiter right around the traps.
I have a similar setup and 3.90's gave me just the room I needed to get to the end in 4th without running into the redline. I really wanted to go with 4.30's in the rear, however it was precisely this issue that helped steer me to the 3.90's.
Old 10-31-2008, 01:49 PM
Midnight02's Avatar
Just to give you a point of reference -- on a 275/40/17 tire with a 6600 rpm redline, you should expect to be at the following MPH in 4th gear (at redline):
3.90's -- 129 mph
4.10's -- 123 mph
4.30's -- 117 mph
4.56's -- 110 mph
Old 10-31-2008, 04:23 PM
GregWS6&z28's Avatar
3.70's with a 28" tire and 4000 stall. will depend on your rev limiter and efficiency of your stall (if auto)
Old 10-31-2008, 10:28 PM
Dustin AZ's Avatar
Why not try and maximize your ET is you're going to be racing the car? Get some good sticky tires, light wheels and a set of 3.73 gears w/ a 26" tall tire (Possibly a 26x10 ET Drag, or a 26x11.5 ET Street).
- Dustin
