Midwest fabb'd 9's, Whats the concencus on weight savings over the 10 bolt?
Well Reading my title I know the fab 9 will weigh a lil more than a 10 bolt. But what are some general figures. I will be running, a fab 9 with back bracing strange aluminum center section, 35 spl axles and a detroit locker. Im sure weights are somewhere in that billion page long thread.
Any ideas,
Thanks Erik
Any ideas,
Thanks Erik
LS1Tech Premium Sponsor
Midwest Chassis bolt-in braced housing... 59#
Moser/Strange 31 spline solid axles 39#
Strange aluminum case/Pro suppport/Detroit Locker 57#
i believe the 98-02 brakes are about 10 #
total... 165 pounds
stock gm 10 bolt with backing plates and aluminum T/A cover is right at 160#
there ya go...
if you were to do a spool and 35 spline gun-drilled and lightened flange axles it gets down to about 150 pounds.
total... 165 pounds
there ya go...
Thanks vert. I have one of your rears just sitting under my car right now. I havent been around the forum much and the last I checked in there was still speculation. Cant wait to get the damn thing in!
It took them a while to get back to me to, they must be very busy. They should just update there website to make it easier for people to see there prices. Here is a copy of my PM.
here ya go...
heres the current pricing schedule:
base package includes housing(any width), Strange iron center section with posi and choice of gear, 31 spline Moser or Strange axles, chromemoly adjustable torque arm with crossmember for your application. this is 2650.00 shipped.
options:
Meziere rear side filler cap assy +30.00
3 channel abs (truetrac or locker req'd) +150.00
4 channel abs axle mod +100.00
new 4 ch. abs rings(if needed) +100.00
Truetrac differential unit +125.00
3.00 or 3.25 gear +25.00
black powdercoating +120.00
housing backbrace +150.00
Strange alum. center, alum support, billet yoke 210.00
Forged alum support and billet yoke(iron case) +65.00
new gm caliper mounts and backing plates +235.00
Strange 3 inch chromemoly driveshaft +295.00
bolt-on race anti-roll bar +350.00
chromemoly adjustable lca's and panhard +285.00
Strange sportsman brake kit +425.00
Strange race brake kit +535.00
Strange or Moser spool instead of posi -100.00
completly assembled rearend ready to bolt-in +80.00 (will need to be supplied with your brake caliper mounts or new ones)
the true fabricated rearend housing features components such as a drain plug, 4 hole relocator style lca brackets, stock style anti-sway bar mounts, brake line clips and hose mounts, and e-brake cable brackets(98-02) all as standard eqiupment at no extra charge.
let me know what you think.
thanks for your interest!
Eric
here ya go...
options:
Eric
