Stock rear/+500whp/stickier tires...
I have a '98 T/A and I need to change my tires, my car has built motor, built 4L60, and suspension, but has stock 10 bolt rear for now and I have no traction under 60mph. I've been using street tires for fear of blowing the rear. My question is, how safe would it be to put a stickier tire in the rear such as a 275 Nitto D.R.? I need more time to gather the funds for a 9" but I need tires now and traction is an issue with normal tires.
Anyone running serious power on an automatic F-body with a stock 10 bolt on sticky tires? If so, please chime in and give some details on how it's holding up. How long before it blew? What combination of power/tires used? etc.
you're running an auto, blew a bunch of money on everything else, next upgrade in your future is a rearend. For comparison, Our 92 Z28 had the stock rear with an auburn and 3.73's, th350 stock shortblock with AFR heads, miniram, ZZ9, and a P600B running 10.90's @124.
10 bolts will hold up to a fair amount.
I have run been running nitto drag radials and mickey thompson drag radials on my stock rear end! Im at about 381 at the wheels and 448 at the crank and no issues with my rear. i do have an auto and launch at 1500 rpms.
I had a stock 10 bolt with a LPW rearend girdle and stock gears. The car is full weight and made 541 rwhp. I have an aftermarket torque arm, double adjustable lowers, and lca relocaters. I ran 26x11.5x15 slicks and the car sixty footed 1.49 and went 10.85 at 125.02 mph. It was still together when I put a 9" from Midwest Chassis in it. I made about 25 passes on it. If you have a transbrake I dont think it will take it. With an ET Street it sixty footed a 1.53.
if you have stock gears and untouched then the stock 10 bolt holds up good with an auto. if you have gears in it, they put more stress the lower you go and all depends on the setup. if you set them up with tight bearing preload and use a solid shim instead of a crush sleave then they do real well. i have sprayed a 175 shot on a built lt1 car and ran well in the 10's with a 10 bolt auto. M6 well...... thats anouther story. haha
