Mikronited gears
Old 11-01-2008, 12:27 PM
zlicious94's Avatar
Default Mikronited gears
Hey guys came across this website about new kind of treatment for gears.wondering if any of you have heard about or have any experience with them. Sure looks good to me! They tested a 2000 t/a on 200 shots and the gears held up fine??http://www.vincihiperformance.com/MI...IN%20PAGE.HTML
Old 11-01-2008, 04:07 PM
john563's Avatar
they use to be a sponsor here..PM predator on here he has 3:73 micronite gears..Keep in mind he is an A4..I may do it since I'm an A4,but if I had a 6speed I would just save for a 9inch or 12bolt
Old 11-01-2008, 11:17 PM
MplSS's Avatar
Six speeds inc offers micronited gears, or at least they used to, but I agree with john563, in a 10 bolt, any upgrade is a waste, especially w/ a 6speed.
Old 11-02-2008, 08:17 AM
ss1
ss1's Avatar
Well, when I wanted to get my gears done, I couldn't get a response from Vinci and heard he may be working directly for Crane now. So, I went to the Crane Cams website since they own Mikronite (or vice-versa) and followed their instructions for getting parts Mikronited. Also, Six Speeds Inc. is no longer in business as of a couple of weeks ago.
I sent the gears in to Crane and had them back in around a week. I think the gears only spent two days there while the rest of the time was in transit. Very quick service, and the gears came back with a mirror finish. I have not installed them yet, so I'll try to take some pictures this afternoon so you can get a look at them.
Old 11-02-2008, 10:10 AM
zlicious94's Avatar
Thanks guys I just wanted to see if I should spend the money or just save for the 9!!
Old 01-11-2009, 06:28 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
I'm bringing this back to the top. I don't plan to run at the drag strip, but would like the added benefit of the mikronited gears. Does it help with quieting down the gears?
Old 01-12-2009, 08:08 PM
ss1
ss1's Avatar
It's supposed to quiet them down, that is why I had it done. They also say it will cut friction and will gain a few rwhp/tw. I still haven't installed them yet so I have no definite real world results for you.
Old 01-12-2009, 10:04 PM
DrkPhx's Avatar
I had mine done a couple of years ago by Vinci. I had to buy new gears (Motive gears in the black box as requested by Roger) for the process. The backlash was slightly different compared to the factory recommended spec as well. While it didn't completely eliminate the gear whine, it certainly hasn't gotten worse after several track runs like the original gears equipped in my Strange 12-bolt. Here's a few pics.
Attached Thumbnails Mikronited gears-mikronite-gear-side.jpg   Mikronited gears-mikronite-.jpg
Old 01-12-2009, 11:18 PM
SoxXpupPeT's Avatar
^ ^ that looks pretty. to bad i have a M6 or else id get 3.73's and have them mikronited and be done with it. instead i need a 9 bolt
Old 01-13-2009, 06:13 AM
UNDER PRESSURE MOD
See, that's my point. I guess my factory 10-bolt is a weak link, but not with 19" wheels and tires. I'm not going to get enough traction to be a concern. My current 3.73s (true GM gears) are whining a little on decel right now. I need to do a fluid swap as it's been a few years, but I'm wondering if the next set I go with I should get Micronited or not.
Old 01-14-2009, 11:30 PM
k0261886's Avatar
I don't believe that they will mikrontie used gears.
Old 01-15-2009, 07:41 AM
ss1
ss1's Avatar
Nope, they will only process a new set of gears.
Old 01-15-2009, 07:58 AM
LS1Tech Sponsor
Robin L's Avatar
I have had several sets done for my previous race car. When Liberty Gears had a Mikronite machine I went through them.
Ring and Pinion would pick up between 6 to 12 horsepower at the wheels on a dynojet.
Later we started to have amm the gears in our Tremec transmissions done. That is harder to quantify but but if it doesn't hurt we do it.
Liberty went to a different process. Mikronite is a trade name. The process is micro polishing.
I use Liberty Gears to micro polish my trans and rear gears.
Robin
Old 01-15-2009, 08:53 AM
UNDER PRESSURE MOD
Thanks for the comments guys. I'm going to do a fluid change while the car is in hibernation and see what the condition of the gears are in. If I need a new set, I'll definitely have them Mikronited or what ever micro polish is available.
Old 01-15-2009, 11:23 AM
great421's Avatar
Default They are much better!
LT1 / 4 M6 3:73 guy here, with my $0.02:
As an indiviudal who has busted 4 sets of non-Mikronited ring and pinion gear sets (Yes, I have the thick cast Aluminum cover; yes the unit has been welded, yes, I have Strange axles; Yes, ALL rebuilds were done by pro NOT by me), I can say that I am very had on my N/A car, but I cannot seem to break these gears! Been flogging on them for about 9 months now.
I love them!
Much less expensive than a 9" or 12 bolt ($300 vs. $3,000) and they've been holding up extremely well.
Once I get the STS on, then the real test will begin!
Old 01-15-2009, 11:35 AM
LS1TECH Sponsor
Jonathan@Tick's Avatar
I think it probably just has something to do with who installed them
I love them!
Old 01-15-2009, 11:42 AM
great421's Avatar
Maybe...
(Yes, Tick put them in. I've taken my broken toy to them 2 or 3 times now!)
Jonathan can attest to the fact that I'm not afraid to drive it like I stole it!
For the record, their black TA is much cooler than mine!
Old 01-15-2009, 02:19 PM
UnZFeat'd's Avatar
...or you could just get a 12 inch... however, i think a 10 bolt wold hold up better than a 9 bolt. hah... if you have an M6, just get a better rear end. You wouldnt want to spend the time and money on the mikronite finishing, only to have it be spewed all over the track one day when you really hook up, would you?
Old 01-15-2009, 09:13 PM
AFTICA's Avatar
Will this process make spyder gears stronger also?
Old 02-13-2009, 03:44 PM
ElkySS's Avatar
does anyone actually have and experience with this?
