road noise
Old 11-03-2008, 07:44 PM
spaulsen's Avatar
Default road noise
ive been noticing alot of road noise from the rear area of the car. i wouldnt think it should be that loud but everything seems to be right. is there any way to quiet it down back there?
Old 11-03-2008, 08:31 PM
wrd1972's Avatar
What rear end do you have?
Do you have poly bushings?
Please create a signiture referencing you car and its specs.
Old 11-04-2008, 03:47 AM
EPP
EPP's Avatar
If it is a roaring type of sound you could have an axle bearing going out, or it could just be out of fluid! I've seen it happen, I went with our roll back three years ago and picked up a Camaro that didn't have a drop of fluid left in the 10 bolt rear. The friction removed all the teeth from the gears and the car would not move. Bob
Old 11-04-2008, 06:32 AM
spaulsen's Avatar
everything is stock. pretty sure it has fluid. but it doesnt sound like a bearing. bearings will somewhat squeel right? well, ill have to check the fluid again but pretty sure its full.
Old 11-04-2008, 06:52 AM
blackodium's Avatar
I had a constant wawawawawawawawawa noise in the rear. turns out it was carrier bearing. (I) thats right i fixed it. well except to get the bearing pulled off and a new one pressed on. drives nice now.
Old 11-04-2008, 07:06 AM
wrd1972's Avatar
Listen to Bob. Bearings do not always squeal. the bad bearing sound can be amplified and its frequency and can change depending on where it is. Like in a big hollow axle tube.
spaulsen's Avatar
cool. ill have to try looking at that.
Old 11-04-2008, 07:07 AM
wrd1972's Avatar
Pinion bearings tend to squeal and scream since they spin faster than eveything else. I agree it might be and axle or carrier bearing.
