1344 u joints??????????
is the 1344 the stock joint front and back for a 2002 M6 camaro???
summit says its a 1344, but others say its a 1310. i want to order new spicer u-joints for a STOCK driveshaft and STOCK rearend.
any help is greatly appreciated!!!
I once found a sheer chart listing all the different u-joints made, the 1310 is weaker. The stock joint in a steel shaft is near equall to the 1330 joint in sheer strength.
There were 3 different driveshafts available from the factory,steel LT1,alum 1LE and alum LS1. The 1LE is the only shaft that uses 1310 joints.
