Is there an additive or spacifice fluid to add
I've got a 1996 Z28. Is there a spacifice fluid to the fluid in the stock rear. I was told that there was a synthetic additive that must be replaced or with normal gear oil the rear will begin to howl soon after. Is this true and is it the posi trac system that it damages?
Torsen does not need an additive. GM had sent a bulletin out some time and that was done to quite a "rusty screw" noise. Also it is at the owners discretion. and it does not affect the durabilty of the differential. I run Mobil One synthetic in mine and it is as quite as can be. It is just a noise thing! I have noticed that synthetic seems to hold up better. IMO
Ok well what if the rear is howling because the fluid was just changed and no additive was added and it just started. Could I add the limited slip additive and I stop or is the rear trash now?
