help with 9"
Old 11-13-2008, 11:16 PM
SPEEDYTRANSAM1996's Avatar
Default help with 9"
found some1 with a 9" for sale for 2k says this ....
This was a mail order Moser with NOD center, "Detroit Locker" ,1350 pinion yoke, 35 Spline Alloy Axles and a 4.10 gear
what would have to be done in order to make it a 3.73 and how much
thanks
Old 11-14-2008, 04:54 AM
EPP
EPP's Avatar
Gears and an install kit, plus someone knowledgeable to install it. $165.00 for the gears and $80.00 for the install kit. Me, I'd run it with the 4.11 gears, you might find that you like them. Bob
Old 11-14-2008, 11:23 AM
Sprayed 99's Avatar
you should try out the 4.11's. that rear is the same set up as mine and its worked really well
Old 11-14-2008, 02:17 PM
qwk93ta's Avatar
I had 4.11s in my 9" and loved them.
