Will Strange retainer/caliper brackets fit Moser?
I know the housing end pattern is the same between the Strange and the Moser but will the Strange caliper brackets/axle retainer work with a Moser? Im guessing it should be dimentionally similar and work fine...but I could be dead wrong. Anyone know?
The Moser housing was built for a 93-97 brake set up and 3 channel ABS that accepts the large Ford bearing. I assume a Strange housing that is built the same way (same year and ABS option) would be similar, and the bracket they supply would fit the Moser.
Bob, do you think this bracket(s) would work....
