10 Bolt Rebuild Kit?
http://www.exoticperformanceplus.com...html?item=1009
Here is the rebuild kit, but does not include spider gears. Bob
Sorry to the mods admins, but I've been looking for a month and this is the only place I've found that sells Spider gears...
http://www.ringpinion.com/ProductDet...px?ProdID=1175
Are these the correct gears for the 10bolt in the Fbod?
Those look to be the correct ones, if you are rebuilding a completely stock rear. Unless you get some clutches or saved your old ones, those will only make it an open differential, not a posi or limited slip.
If it has an LS1 theres a good chance it has some sort of limited slip. Those gears pictured are not for any type of limited slip.
I don't think anyone will care about losing the business on a 10 bolt rebuild. Atleast when it blows up again they can't be held responsible. J/K
Why are you looking for spider gears? They are not a normally replaced part of a posi. I went with a Ratech deluxe kit. It comes with all bearings, seals, and shims needed for a complete rebuild. I would get a Fel-pro diff gasket though, the cork one that comes with the kit is crap.
The next thing you need is a rear end guru that knows what he is doing. The kit won't do any good if the install sucks.
