is my rear end at risk?
Old 11-29-2008, 04:45 PM
02 T/A 984's Avatar
Default is my rear end at risk?
got a m6 putting out 393rwhp....is this enough to break the rear end
Old 11-29-2008, 04:57 PM
Reboot's Avatar
if you're driving at the track....yup
Old 11-29-2008, 06:48 PM
supernaturalta's Avatar
Yepper.
Old 11-29-2008, 07:31 PM
Darksol's Avatar
Don't drop the soap! You're on borrowed time...
Old 11-29-2008, 10:57 PM
SladeX's Avatar
I was hoping my 10 bolt would take me to 150K at least, but I've gone 130k and its dying. It died due to having to park in a place that forces me to do a lot of steep angle left turns.
Normal driving killed the previous 10 bolts on my other Camaro. Don't waste money on the 10 bolt, save for the 9 inch and don't look back. Unless you are A4, then 12 bolt.
Old 11-30-2008, 01:21 AM
Kingc8r's Avatar
You can break the rear end with a stock M6
Old 11-30-2008, 01:38 AM
35th SS's Avatar
thats the words.your on borrowed time.it will break.
Old 11-30-2008, 02:39 AM
camd01silv's Avatar
I broke mine easily at 370rwhp. Of course that was a 4500rpm clutch dump at the track with drag radials... Yes, you will break yours easily at your power level, if you try to launch it hard at the track. If you take it easy with the launches, it will last a little longer, but you still need a 9 inch. I should have bought a 9 but my 12 bolt has held up just fine so far.
Old 11-30-2008, 09:20 AM
SweeTbone's Avatar
I'm not liking this thread. I'm fiending to go the track but I have to be able to drive home also. Guess I'll be bogging off the line.
Old 11-30-2008, 10:48 AM
RacerXLs1's Avatar
Yea i would say its on borrow time..
Old 12-01-2008, 11:51 AM
Sprayed 99's Avatar
its only a matter of time. broke my 10 bolt 3 times on the street when the car was dead stock. good luck
Old 12-01-2008, 02:59 PM
koolaid_kid's Avatar
I agree. I know someone who broke his with a stock SS. Fortunately for him, it was still under warranty.
Old 12-02-2008, 03:39 AM
2001ws6-500hp's Avatar
is it normal for my 10 bolt to get posi on left hand turns but not right hand turns? i kno this sounds dumb.
