girdle cover worth installing?
Old 11-30-2008, 11:34 AM
camar0corey's Avatar
Default girdle cover worth installing?
Well my 168k 10 bolt has finally died. I stuck mikronited 4.10's in there two years ago, seems the differential is what has died, its hard to make 90 degree turns now. It had a thunder racing cover on it. I'm sticking a completely stock 10 bolt in its place, I have no where the amount of funds I would need to upgrade to a better rear. Is it worth transferring the thunder racing cover onto the new used 10 bolt? I already have it, does it def. help things survive?
Old 11-30-2008, 02:08 PM
35th SS's Avatar
I would transfer it over.anything you can do to make it last longer.
Old 11-30-2008, 02:58 PM
FLSSLS1's Avatar
before you put a cover on make sure you install a ARP stud kit for the caps. The factory bolts are a weak link and need to be replaced with a stud kit. Very simple to do if you're doing it yourself. TA sent me the kit when I bought my cover.
Old 11-30-2008, 03:49 PM
ski23's Avatar
I think it makes it a lil stronger. my m6 car seemed to last longer between gears sets with the cover on.
Old 11-30-2008, 10:43 PM
Thanks for the heads up on the stud kit FLSSLS1, I think I had done that when I put the 4.10s into the last rear, I'll have to see if I have the receipt here still from Thunder Racing when I ordered the parts. Hopefully I did and I won't have to order them.
Can't wait to go back to a stock rear though, the 4.10s were fun on a roll, but with street tires it never even attempted to not spin at the track, best 60' was 2.2, usually averaged around 2.4. I was getting tired of them whining back there, and seemed to affect the constant rpm cruising smoothness. Any time they were checked though they were still setup good.
Old 12-03-2008, 10:07 PM
XtraCajunSS's Avatar
If you bought it in a kit from us, chances are you have the stud kit. It is part of the kit we sell for $399. I can look up the order for you if need be. Just PM me your name and info.
Thanks
Shane
Old 12-03-2008, 11:02 PM
jsteele90's Avatar
band aid for a bullet wound
