H/C+Spray+T56 = what rear?
Old 12-01-2008, 10:49 PM
BarneyMobile's Avatar
Default H/C+Spray+T56 = what rear?
I in the market for a stronger rear. I'm pretty much set on a Moser 9inch, But my dilema is weather to get it with a trutrac, a locker, or a spool. Its spends 95% of its time on the street as a DD. Because its a DD, I would love to have the trutrac but with the nitrous my car makes 600ft/lbs at the wheels and its a 6speed car. I plan on launching hard on slicks at the track and the car is full weight. What route should I go?
Old 12-02-2008, 08:38 AM
LS1TECH Sponsor
Steve Burger's Avatar
Locker at a minimum. That will alos allow you to tun a 35 spline axle.
Old 12-04-2008, 09:20 AM
blk00ss's Avatar
I hated my locker with a six speed. Very aggrevating. Every time you change gears or let off the gas and get back on the gas the whole car wants to "wander" all over the place. I swapped my locker out for a spool. I wouldn't have anything else. Also I don't know why eveyone gets hung up on 35 spline axles. I've never seen a 31 spline break. That's what I have and I have cut low 1.6x sixty foots with a 3600lb car with 740ft lbs of torque.
