c-clip eliminators
c-clip eliminators
well, i have a question about c clip eliminators. i know that nhra does not allow the use of factory c clips if you run faster than a certain time. so i cant find any eliminators that will work with the stock rear. i dont have the jack to but a 9in or 12 bolt. what r u guys doing to solve this problem other than buying a new rear?
yea i have checked with moser and strange but they told me that they will not work on the 28 spline stock axles. that why i posted. unless you know something they dont, let me know. thanks, shawn
Well it woundn't be worth it to me but you could always up grade to more splines and a new diff., but it's a 10 bolt........i say juts take your time and save for a 12 bolt or 9", they aren't to badly priced used on here.
If you are concerned with the NHRA c-clip rule, then that means you must think you will be fast enough so I applaud you for taking it seriously. Also if you are going this fast, its only a matter of time before the 10 bolt goes kabbom.
Why not consider getting a 9" rear end which comes standard c-clip eliminator setup. Why throw good money on bad money.
