10 bolt buildup?
Old 12-14-2008, 01:53 AM
My LT4 Z's Avatar
Default 10 bolt buildup?
I built up my motor with a new cam, intake, LTs, a tune and a few other trick parts. Im hoping to be at around 370 hp to the wheels. Ive already decided on a TH350 soon, so all thats left is to deal with the rearend. I wanted to pick up a 9" from a junkyard and build it up but Im already putting 3.73s in the 10 bolt and was wondering if theres anythinng else to do to a 10 bolt to make it hold up to the 370rwhp and a set of slicks. I was thinking the brand new gears, some new fluids and gaskets, and 35 spline axles w/ c clip eliminators, if needed, i dont really understand rearends too much. Would the higher spline axles, fluids/gaskets, and gears make my rearend strong enough to hold the hp and slicks?
Old 12-14-2008, 03:24 AM
TireSm0ke's Avatar
Not worth is bro, id say it could survive with that setup but slicks will destroy it in a very short amount of time. Gears wont make it stronger either... unfortunately the only way to go is to upgrade to a 9 inch, 12 bolt, or even s60. Be careful with a junkyard 9 inch though, its gonna take alot of fabricating to get it to fit on an fbody. Dont put any money into the 10 bolt, just save up for a new rear imo.
Old 12-14-2008, 04:04 AM
SMALLBLOCKHERO's Avatar
just in case you decide to try and make the 10 live for a while. heres a great write up about building one.
http://www.highperformancepontiac.co...ild/index.html
Old 12-14-2008, 11:52 AM
SSTYCOON's Avatar
TA girdle, ARP studs, Weld the pumkin and axle tubes together...
Then start a 12 bolt fund for when your "built" 10 bolt blows up. Somethings gotta give bro, rear end or your tires!
Old 12-15-2008, 12:19 PM
My LT4 Z's Avatar
Makes sence. Thanks for the help. Im just trying to get the car together. I spent so much money trying to make an LT4 powerful, Im sure I could have thrown in a 12 bolt, th350, and a used ls1 with a nice cam in it for around the same price...O well, hindsights 20/20.....
Old 12-15-2008, 01:22 PM
ndfrsd6's Avatar
like said its not worth it to build the 10 bolt ....just milk it till you can save up for a 12 bolt or 9in
Old 12-15-2008, 09:26 PM
SSTYCOON's Avatar
Sounds like you have a great project going, Nothing wrong with an LT4.. some say they sound better than a LS1, I hope the rearend will last, just take it a little easy out of the hole at the track and I think you be OK. good luck!
