first mod - Gears or Stall?
Old 12-16-2008, 07:33 PM
dondb's Avatar
Default first mod - Gears or Stall?
2002 camaro SS - I don't track or drag the car. I only use it on nice summer days and would like to get a little more kick out of it. I currently have a 345 HP package, stock 3:23 gears, GMMG chambered exhaust, ported TB and a diablo tuner. Do i put in a 3200 stall or 3:73 gears? Would like to get some input from the folks on ls1tech...thanks for your input!
Old 12-16-2008, 07:42 PM
twitchtwice's Avatar
you'll deff feel more from the stall, and im guessing you dont mean the stock 3.73 gears
id say go with the stall
Old 12-16-2008, 07:44 PM
dondb's Avatar
Thanks --edited to 3:23 gears
Old 12-16-2008, 07:56 PM
sasquatch's Avatar
Personally I would do the gears first then the stall. Even though your going with a 3200 I wouldn't want to drive around with a higher stall on factory gears. just my own opinion
Old 12-16-2008, 07:59 PM
EDS01SS's Avatar
I did 3.73s first and there is not that much of a difference. go with the stall first,its a much better bang for your buck.
Old 12-16-2008, 08:08 PM
FirstYrLS1Z's Avatar
Since you've already got 3.23s'(as compared to those that have the 2.73s'),you would be increasing the torque to the carrier and axles by 15% at all speeds and in all transmission gears.It's something you would definitely feel.A change in torque convertor stall from the factorys' low stall to a higher rpm stall,as in the 3000-3500 range,will bring the ls1 engine up into its' better power band almost immediately and the rush would be higher than gears.
convertor over gears,eventually do both.
Old 12-16-2008, 08:10 PM
FASHOOTER's Avatar
Get the stall! Way more fun than gears!!!!!!!!
Old 12-17-2008, 11:55 AM
dondb's Avatar
going to order my new stall today! Thanks for the input.
Old 12-17-2008, 12:31 PM
RooRnZ28's Avatar
+1 for the stall.... a 3000 really woke up my car when it had 2.73's. You wont be disappointed! Now dont forget a tranny cooler!
Old 12-18-2008, 07:34 AM
dondb's Avatar
Just bought a Level II tranny with a billet 3200 rpm stall from Performa built! There is a special going on (last day today) where you get the Level II for the price of the Level I. My car is in storage for a few more months, when i get her out, i'll report back with the details of the tranny and stall.
Old 12-18-2008, 07:41 AM
99_Z28's Avatar
Definitly do a stall, it will feel like a different car. But go with atleast a 3500. I wish I went with a 4K.
Old 12-18-2008, 11:42 AM
PewterScreaminMach's Avatar
If you had 2.73s I recommend the gears but since you've got 3.23s, I'd go with the stall first. The gears will see an improvement going to 3.73s but not as much as being able to launch from a much higher RPM on a slightly longer gear.
Old 12-19-2008, 10:52 PM
01ssreda4's Avatar
good decision
Old 12-20-2008, 12:13 AM
Ls1Rook's Avatar
Any vids with 3000 and 3500 stall difference
Old 12-20-2008, 01:29 AM
marc97taws6's Avatar
Combos work out the best.. get those 3.73's next buddy!
